Did they lock up after you used the brakes, and then act like one caliper wasn't releasing? I've had that happen but not on my pickup. Turned out to be the rubber brake line.
very common. due to the metallic brakes basically rusting overnight. i replaced my pads and solved the problem. i used metallic again, aftermarket and problem was gone. my problem was on the rear.
