do 285/75s fit on 16x10s
Brandon, The 16x10 will work, but you could also go with an 8. I think that the 8 would be better though. With the 10" wide rim and the 285s it will create sort of a "bubble" effect with the tire, which I think looks pretty bad. The 16x8 wouldn't really do that. It would make the sidwalls stand more upright instead of bow out.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
265/75 R16 Uniroyal Laredo M/Ts
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
[This message has been edited by powerstroke73 (edited 12-17-2000).]
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
I'm set up (out of ignorance) with Bridgestone MT Dueler 285/75/16 on 16x10 AR's. I wanted a mud tire that would contribute to handling (there's a contradiction). I got 4 unanimous opinions from 4 different sources that said that setup would be okay, (and Bridgestone's recommendation was 16x8 to 16x10) though I had to be careful not to rub curbs with the sidewall because of the stress created by the bowing. I've been real pleased with the setup. No adverse effects on suspension or tires, that I've found after 12,000 miles.
