rim brands?
Actually, there's a decent amount of wheels out there for the 5x135 bolt pattern. The big three I looked at were Weld, American Racing and Eagle Alloys. I can't recall the websites, but if you search you'll find some good ones that show many more wheels than you'll find at regular 4wd websites.
I'd go with a larger rim and less tire. It'll handle better cause your sidewall won't flex as much. For the same reason, the ride MAY be a bit rougher, but it's a truck - I don't think you'd ever see the difference.
Mike
Mike
Almost every wheel company sells rims for an f150. 5x135mm may seem like a strange bolt pattern, but it must be remembered that the same pattern is used on both expeditions and f150's(the #1 selling vehicle in the world). That is a huge market which many accessory companies take full advantage of.
I personally run American racing AR 23's. They were pretty cheap, and they look nice too.
https://www.f150online.com/galleries....cfm?gnum=3445
