BF Goodrich All-Terrain T/A KO's
Old 01-31-2001, 08:00 PM
bluecrab's Avatar
Question BF Goodrich All-Terrain T/A KO's
I'd like to replace my stock Goodyear Wrangler P255/70R16's with something a little bigger.
I'm seriously considering the BF Goodrich All-Terrain T/A KO's sized at LT285/75R16.
But, I have a few questions.
First, do you think these tires would be too obnoxious (big) for my SuperCab 4x4?
Second, are the tires noisy at highway speeds? I want a relatively quiet tire.
Third, do the tires run smooth and true at highway speeds? Do they provide a reasonably comfortable ride?
Fourth, how do the tires perform? Both on road and off road?
And finally, how much did you pay?
I'd like to see some photos of a truck similar to mine with the same tires on stock rims.
Basically, I'm looking for a larger tire that runs great on the highway, and to a lesser degree, off road. The tire needs to be quiet running and handle nicely on wet and dry pavement.
Thanks!
1998 F-150 SuperCab XLT 4x4 w/ 5.4L, AirAid FIPK, Gibson SS "Cat-Back" Performance Exhaust, SuperChip.
[This message has been edited by bluecrab (edited 01-31-2001).]
Old 01-31-2001, 08:12 PM
bluecrab's Avatar
Post
Just updated my signature to include a picture of my truck.
1998 F-150 SuperCab XLT 4x4 w/ 5.4L, AirAid FIPK, Gibson Swept-Side stainless steel exhaust, SuperChips "SuperChip".
Old 01-31-2001, 09:26 PM
Matt90GT's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by bluecrab:
</font>
NO
</font>
NO
</font>
That is 2 questions.
Yes, and Yes
</font>
In a simple answer, EXCELLENT!
</font>
For that size they are like $140-160 each. Just shop around and see if someone will price match or beat another competitors price locally.
Old 01-31-2001, 09:32 PM
Matt90GT's Avatar
Post
oh you want pics. I have some poor ones but hey:
[img]http://members.home.net/mjbobbitt/f150/f150wheels.jpeg
[/img]
That is an Eagle Series 171 16x8 wheel with the BFG 285/75/16 AT KOs
[img]http://members.home.net/mjbobbitt/f150/f150_side.jpeg
[/img]
Crappy side pic. Hopefully the weather will warm up and I can clean and get new ones.
[This message has been edited by Matt90GT (edited 01-31-2001).]
Old 01-31-2001, 11:42 PM
Jon P's Avatar
Thumbs up
I just put these on my Expedition. Here's the thread, which includes links to photos.
https://www.f150online.com/f150board...ML/000743.html
In short, these are great tires. They ride and handle better than the stock Godyears. I have the same size tire on stock Lariat wheels on my F-350 PDS Superduty, and they're great on that truck, as well. The stock wheels are only 7" wide, and BFG recommends a 7.5" wheel. Mounting on a 7" wheel may cause the center of the tread to wear out a little faster, but lots of people do it.
97 Expedition XLT 4x4, Black, 3.73 LS, 5.4L, leather, all options except LLS, Edelbrock IAS shocks, BFG AT KO 285/75/16s on American Racing Atlas 16x8
Old 02-01-2001, 06:44 AM
JohnD's Avatar
Post
Go here and you can see a picture of my truck. 285's on stock 16x7 rims.
https://www.f150online.com/f150board...ML/000139.html
Old 02-01-2001, 07:50 AM
bluecrab's Avatar
Post
JohnD...
Those BFG's look awesome on your truck! I've basically got the same truck... same stock rims and such. Thanks for the photo, now I am getting anxious to buy the new tires.
Matt90GT...
The BFG's look great on your truck too... You have the off-road package, no? Then that means that you have 17" rims?
Old 02-01-2001, 09:08 AM
bluecrab's Avatar
Post
Ok, a couple of more questions.
I ran the new tire size through the tire/gear calculator (http://www.andthensometoo.com/calc/tiregear.php) and here are my findings:
The stock Goodyear P235/70R16's are 9.3" wide and 29" in diameter... which are the measurements that the PCM is calibrated for in calculating speed (MPH).
My "optional" Goodyear P255/70R16's are 10" wide and 30.1" in diameter. My speedometer is currently off by a few MPH because of this. The tire/gear calculator says that my speedo will read 60 MPH when I'm really travelling at 62.3 MPH.
The BFG P285/75R16's are 11.2" wide and 32.8" in diameter! The tire/gear calculator shows that when my speedo reads 60 MPH, I'll actually be travelling at 67.9 MPH!!! Talk about a speeding ticket waiting to happen!
Also, my 3.55 gears are 3.55 with the stock tires, 3.68 with my optional Goodyears, and 4.02 with the BFG's!
So, it looks like I'll definitely have to have my speedo (PCM) recalibrated. And it looks like I'm going to lose quite a bit of low-end torque. Anyone know what's involved in recalibrating the speedo?
Old 02-01-2001, 01:39 PM
Lok N Load's Avatar
Wink
Bluecrab,
Fixing your speedo is nothing more than changing a small plastic gear. There is a fitting on the very back of your transmission held in by one 11 mm nut. Take that off, pull the fitting out and there's the gear. Be careful when you take the clip off that holds the gear on. Count the teeth on your gear, notice whether the splines go from right to left or left to right with the "tip" up, and figure out what the percentage of change is from your original tire size to your new tire size (you need that % fewer teeth on your new gear). Go to your nearest dealer, spend $8.00, then reverse the process to put it back together. It just took me longer to type this than it did to change my speedo gear. Just to give you an idea, I went from 255/70-16 to 315/75-16. Went from a stock 20 tooth black gear to a 17 tooth green gear. Sorry this is so long, but I hope it helps.
Lok
1997 F-150 Supercab 4X4,Royal Blue,4.6 V-8, Tow Package,3.55 LS,
K&N FIPK,Performance Accessories 3" body lift,Superchip,
Gibson Supertruck Exhaust,Smitty Nerf Bars,
16X10 Eagle 589's, 315/75-16 A/T's,
Alpine CD,Alpine 5 Channel Amp,PPI 5 X 7's,
Boston 10" Sub.
Pics at: http://www.f150world.com/loknload/
[This message has been edited by Lok N Load (edited 02-01-2001).]
Old 02-01-2001, 06:19 PM
kman's Avatar
Post
Bluecrab
You calculated your gear ratio incorrectly.
With the bigger tires your effiective ratio is smaller in number. IE with the 32.8" diameter tire your effective gear ratio will be 3.13 instead of your factory feel of a 3.55. This is why when you get bigger tires you get a larger numbered gear ie go to a 4.11 and your truck will feal closer to the factory.
You can only change the speedo plastic gear on the 97 and 98 model year's after that it is adjustable via a computer at your local ford dealer. You may have to lie about the tire size and gear ratio to get it correct.
Old 02-01-2001, 07:59 PM
bluecrab's Avatar
Post
Lok N Load...
I love the pictures of your truck. I have a question, however...
As you know, I want to put BFG All Terrain LT285/75R16's on my stock 16x7 rims. One of the reasons I want a bigger tire is to fill the wheel well a bit more on my 4x4... the stock P255/70R16 Goodyear's just look too small for the truck. Another thing I want is a bit more width, or "reveal" as you call it... How did you get the reveal on your truck? Will the larger tire do the trick or do I need to put spacers behind my rims? Or do I simply need wider rims? Thanks!
Old 02-01-2001, 11:29 PM
Lok N Load's Avatar
Thumbs up
My wheels are 16 X 10 wheels. They stick out because they are so wide and because of the offset. So if you want a reveal like that, you'll have to go with wider rims.
Lok
Boston 10" Sub.
Old 02-02-2001, 12:21 AM
mudder's Avatar
Cool
285 BFG's are great. They have never rubbed once, not even off-road.
Old 02-02-2001, 12:22 AM
mudder's Avatar
Wink
Forgot my sig:
Patrick aka Mudder or MR.Daylighter of Arlington Texas (D/FW), member of the Texas Chapter club DAYLIGHTER edition F150 ®, Black 98 S/S S/C F150 4x4 0RP 5.4 V8 3.55ls, Ramsey Pro 8000 hidden winch, Grizzly roll bar, Superwhite Bulbs, 2 Baja back up lights, 2 KC 57 Series 5x7 100 watt long range lights, 2 KC 55 watt fog lights (all-season kit) 10 165 watt KC Daylighters, 2 chrome, 4 Stainless, 4 black ( with 14 KC's, I come alive at night), Manik grill guard, Westin step bars, Rhino Taillight guards, Magnum bug shield, Sonic aluminum treadplate 36" tool box, Flowmaster 40 series dual exhaust, Airaid High Flow system, Edelbrock IAS shocks, 285/75/16 BFG AT/S KO, American Racing Baja wheels, Pro Comp headlight blackouts, Red Top Optima battery, personalized plates, Cobra 18WXST CB radio with 3' whip antenna, Escort Laser/Radar detector, Nokia cell phone, a Mobil Speed Pass on the back window, 3 F150World stickers, a Texas Chapter of F150World.com sticker, a BIG KC block sticker on the back window and a DAYLIGHTER sticker on the front windshield, and yes, I also have been infected with the infamous door crack. More to come for the Daylighter: JBA headers, superchip, 1 more Daylighter for the front, 2 KC reverse Lights, a Lighted Ford tailgate logo, and a 4" Rancho suspension lift (yes boys and girls, it's just about time). If you would like to see pics, email me at Mudder@TexasChapter.com
Also the Moderator of the Ford Trucks vs. GM trucks and Ford trucks forum over on fordvschevy.com so check it out.
Check out the Toughest SOB in the WWF crush the Rock's Lincoln: http://www.amta.net/files/sc-2.avi
OH HELL YEAH!
2 BRT 4U "Go ahead, flash your brights at me, see what will happen."
Got light?
It's a KC thing.....you wouldn't understand.
Candlepower to date: 4,214,000. Gonna add more soon.
See all my pics at my zing.com site: http://www.zing.com/album/?id=4294059243
Also check out www.F150World.com/Mudder
Old 01-06-2005, 11:11 PM
Deertrembl's Avatar
Blue,
BFG KO's are definitly the way to go. Ive had them on my truck for about a month and they look way better than the stock Wranglers.
There arent noisy at all, not like i can really hear them over my duel exhaust. We just got 2" of ice down here and i was running around in 2wd the whole time and had no problems. They hook up like no other. They are well worth the money and if you rotate them regularly they will last forever!!!
Quick Reply: BF Goodrich All-Terrain T/A KO's
