Difference Between 10" and 12" wheels?
![Talking](https://www.f150online.com/forums/images/icons/icon10.gif)
Hi all!
Can anyone tell me what differences there is between a 10 and 12 inch wheel besides 2 inches. Do they handle or ride any different on blacktop?
I'm running with 10's now but am considering buying some 12's. They recommend 12" wheels on the sidewall of my tires but really like the way they handle now and don't want to mess up a good thing.
Thanks, Scott
97 F-150 Black, 4x4 XLT ext.cab,sb,w/Offroad Package,
4" Suspension lift, 3" body lift,
4.56 gears w/LS,
Flowmaster 50 Series w/ duals out rear,
36x14.5x16 Parnelli Jones Dirt Grip tires,
16x10 Eagle Alloys 589 wheels,
Pre-Runner Bumper w/KC Daylighters,Steel Horse Billet Upper and Lower Grilles,
Kodiak Sidewinder Steps,
Pro-Comp Front Skid Plate,
Summit Aluminum Diff cover,
Rancho 9000's and remote,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Clear corner lenses,
Altezza style Tailight covers,
Bug shield,Tinted windows
Sony ES Mobile head unit,Sony ES Mobile changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://hometown.aol.com/squanto804/scottwebpage.html
Thanks, Scott
4.56 gears w/LS,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Check it out at:
Hey man,
Don't know what kind of lift you have, but was considering getting my truck lifted and Fabtech said that the 4 5/8 backspacing will work with their kit. Don't know if this will help or not.
SpliT
2000 Work Series
Deep Wedgewood Blue
Standard Cab 5-Spd
4.2L V6 3.08 Gears
Mean Streak Cat-Back Exhaust(Anyone else have one, I hate mine)
Weld Super Single Wheels
Pioneer Deck DEH-P7200
Tinted Windows
Clear Corners
Superchip
AutoMeter Tach(Not Installed Yet)
Future Mods: FIPK, Bedliner, Billet Grille w/ Painted Grille Surround, Color-Keyed Bumpers, 6.5" Fabtech Ultimate Suspension Lift!!!
Email Me at: F150v6@Aol.com
SpliT
2000 Work Series
Deep Wedgewood Blue
Standard Cab 5-Spd
4.2L V6 3.08 Gears
Tinted Windows
Clear Corners
Superchip
![Post](https://www.f150online.com/forums/images/icons/icon1.gif)
Hi Scott, in my opinion and being my truck a daily driver I would go up to 10" with the right backspacing, no more. It would create too much stress on steering and suspension components unless you can custom fabricate a set of wheels with special specs like backspacing and offset to minimize this. Your tires look great in those 10" wheel, but imagine what can happen with 12" wheels on the rubbing department. If we move out too much the OEM wheel centerline may affect handling negatively and if we add the unsprung weight of those heavy meats to this changes it is going to be worst. It can be done but it's going to take something back. It is going to be a nightmare unless you are planning to go taller.
Some day someone will have a 16" lift on one of this trucks and 14" wheels.... this is something that never stops...![](https://www.f150online.com/f150board/smile.gif)
My Ride: 1998 F150 4x4 Lariat Supercab Flareside 5.4L in Oxford White/gold, ORP, Tow Package, 3.55 Gears.
Modifications:
Split Fire Spark Plugs
K&N FIPK
Gibson Supertruck Exhaust System
Stepshield door sill protectors
Performance Accesories 3" Body Lift
Superlift 3" lift blocks
Performance Lift Lips
Gabriel Gas Ryder LT VST Shocks
Daystar Front Anti-sway Bar Polyurethane Bushings
Heckethorn Steering Stabilizer
35x12.5R16.5LT BFG All Terrain KO's
16.5x9.75 American Eagle 589's.
Photos at: http://www.communicomgroup.com/jmtruck
Modifications:
K&N FIPK
Hey Scott, do you remember that 97 white supercab with big MT's? It was one of the first lifted F150's that I saw. If I can find a photo I will send it to you. Maybe we can find the e-mail address of the owner so you can contact him. I am almost sure that I have a photo and the address somewhere in my address book.
I will let you know. Talk to you later.
![Question](https://www.f150online.com/forums/images/icons/icon5.gif)
Scott, is your last name Isbrecht? If that is the case I have two e-mail addresses for you and I just sent to you the information of the pick up with 12" rims. I sent that to your address in aol, or do I have to use the other one? Let me know.
Modifications:
K&N FIPK
Modifications:
K&N FIPK
JMTruck, Thanks for the reply.
The backspacing appears to be the same on the 10's as it is on the 12's, 4 5/8. Am I missing something? Wouldnt the 2" move the tire out, not in. I see you point about the stress but it is only 2 inches with the same tires. I could see it affecting it a bit but do you really thing it is that big of a difference? and as far as rubbing, it looks like it would only rub a bit with the tires sharply turned with the suspension copressed. I'm wondering if it wider stance would handle on the street basiclly the same?
As far as how loud the Dirt Grips are, best way to describe it is, louder than BFG Muds and quiter than Super Swampers.
Not sure if that answers you question.
Thanks for your help, Scott
