I need a brake job
I need a brake job
Allready put another set of motorCRAP pads on at 38000 miles and had the original rotors turned then. Now im at 51000 and this thing shakes like a dog ****ting a peach seed. I want to fix this thing once and for all or at least for a long time.
Can slotted rotors be turned?
Will aftermarket brembo rotors (non slotted or drilled) hold up better w/o warping than the originals?
What pads do you guys reccommend?
Im sure the 33'' tires add to the stress on the system but ive got to get it taken care of and it has to last.
Thanks for the input...Gordon
If you haven't read this thread yet there's good reading there.
Basically drilled and/or slotted rotors would be good for your application (large tires).
From what I understand rotors don't actually "warp" but the metal changes by extreme heat (hot spots) that change the metal composition of the rotor which in turn makes parts of the disc have more friction than other parts and this is what you feel as "warped".
on
Rotors can indeed warp. This can be measured with a runout guage. Hot spots are another common problem that gives the same feel through the pedal as you have described.
I went through several sets of rotors on my wife's 98 Contour fighting warping every few months.
I finally ponied up $110 each for cryo-treated rotors for her car. It's been six months with ceramic pads and no evidence of a re-ocurrance of warping.
Steve
Steve
