Super Duty Tires (need a little info)
My Dad has asked me to put new tires on his truck while he is gone on vacation :-) His truck is an 02 F350 4x4 SRW V10 supercab w/ 8' bed
I need a little info:
What is the stock tire size (he couldn't tell me off the top of his head)
and if I'm going to put wider (maybe a little taller, but not much) tire on, what is recomended?
He wants an agressive tire, but not a mudder, so I figure I'll have set of BF Goodrich ATs put on - but what is out that will allow me to keep the 'E' load rating?
Thanks,
36
Thanks,
36
The stock tire size for that truck is LT265/75-16
Bridgestone Dueler Revo's (I have them on an 00 F-150 and recommend them highly) come in that size with a C, D, or E load rating:
http://www.bridgestonetire.com/dpp/s...productid=1055
Yokohama Geolanders A/T's are also a good LT tire:
http://www.yokohamatire.com/pdf/geoatpls2.pdf
And the BF Goodrich All Terrain’s you are looking for look like they are only available with D load rating:
http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
Call a couple of tire shops to see what equivalent sizes will fit that truck, but I would not go very far from the stock size. I hope your dad gave you a budget to spend cause good All Terrain tires of that type and size are probably $175-225 each.
Hello 36fan,
You could upgrade to a 285/75-16 but you may have an hard time finding a "E" load rating in that size you are most likely going to have to stick with the stock size. One of my favorite tires because of the aggressive tread pattern is the Cooper Discoverer S/T and S/T-C. They run about $130-$150 and make a 265/75-16 "E" load rating, check it out. You can also search on tirerack.com by size, they have a good selection and low prices.
Cooper Tire
http://www.coopertire.com
Tire Rack
http://www.tirerack.com
Cooper Tire
Tire Rack
When I pushed him for a price range, all he was said is, "Set it up like you did yours." I told him I couldn't afford to set mine up the way I wanted to, he said, "Well I can." So I get an unlimited budget for tires, and he wants me to do the brakes, too (i.e. - aftermarket rotors)
I saw that the BFGs come in 265/75/16, 285/75/16, and 305/70/16. The 285s and 305s essentially have the same diameter.
Is anyone running the 305/70/16 size? I want to ensure their wouldn't be a rubbing issue.
