Need some help!!!!
Need some help!!!!
I have a 2002 FX4 4x4 with 42,000 on it. I have recently noticed a pulsating sound when I brake..........woowoowoowoowoo or humming like a truck with thornbirds or something, but it only happens when I hit the brakes. Is this my breaks rotors or what. My tires only have 1/8th inch of tread on them so I was thinking it could be my tires but it only makes the noise when I brake. Anybody have any ideas, I would greatly appreciate some input.
https://www.f150online.com/galleries....cfm?gnum=3016
you say "pulsating sound". If it is a pulsating feeling from the brake pedal (not a sound) then it is very likely your brake rotors. With the sound you describe, i'd suspect bad brake pads, possibly bad rotors, wheel bearings or loose calipers. i dont know much about 4X4's though so maybe something about the 4X4 setup is contributing to the noise.
Yours could be a whole lot of things: Tire noise, wheel bearings, or brakes all come to mind. I'd put my money on the brakes as mine did that exact same thing for about 4 months. Turned out to be the lower slide pin on the driver's side froze up, causing the inside pad to wear out prematurely. Got my truck a brake job for Christmas.
-Joe
-Joe
