Why ceramic pads?
Softer? Wear faster?
I cannot say that I know, but that does not sound right. True, ceramic pads are supposed to be cleaner, but I think they are harder and wear longer...I just had my brakes done, and the place I had them done put on "lifetime warrantee" ceramics, meaning that if I still have the truck when they wear out, the pads are free. (still have to pay to install 'em though)
I was also told that ceramic was standard on the front brakes. Is that true?
TS
TS
texas steve, ceramic pads dont contain much, if any, steel or wool (conventional semimetallic pads do) . Ceramic and a small amount of copper are the major ingredients in the ceramics. Semimetallics are indeed harder on rotors (from what i have read). I can say for sure that neither the Ford OEM pads on my truck nor the replacement ceramics produced any black wheel dust on the wheels. i went with ceramic as an experiment but they have served me well (abut 30000 miles so far and no problem). kw in sugarland tx
I had the NAPA Cermix on my last F-150 and plan to get them again. $75/set, but you'll need decent rotors to handle the extra heat. My $35ea Autozone ones warped in a year.
Cermic brake pads are not that much more (parts) than anything els.e I see $50/set all over the place for semi-metallic so $75 isn't much. Upgrade the rotors later when you have more money. but, if you are paying someone else to do the work, it isnot worth paying $125 for brakes now and another $300 later.
