Mickey Thompson Baja HP for a 17" wheel?
![Post](https://www.f150online.com/forums/images/icons/icon1.gif)
I have a '97 F150 SC SB 4x4 ORP. I want to put M/T's Baja HP on, but don't know what sizes they make for 17" wheels. I would like to put on some 33x11.50, 33x12.50, 34x11.50, 34x12.50 or something in between (if there is anything). I would be willing to make small suspension mod's (adding new shocks, coil springs, and anti-sway bars), but not body or suspension lifts. So I guess my two questions are:
Does M/T make the tires I am looking for?
Do I have to add anything to make them fit?
pickupman: M/T does make the 34X11.50 for the 17" wheels and the make a 31X10.50 as well but that is not any larger then stock but to fit the 34 under your body w/o a lift that might be a trick have you cranked up torsion bars to make your truck sit level try this, and talk to someone about putting a add a leaf in and new coils you might make it but you will end up with a tar baby no off roading with that set up..
99 F150 x-cab ORP bright red
crom rocker pannels flowmaster
tunnel cover
putco bed rails
lund bug guard
headlight covers
in-dash cd player
tunnel cover
putco bed rails
lund bug guard
headlight covers
in-dash cd player
Mickey Thompson makes the exact same size tire as your stock 17 inch tires in the Baja.....
98 F-150,4x4, 5.4L,Lariat,Ext. Cab, Gibson Cat-Back, Airaid (FIPK), Bulldog Stainless Nerf Bars, Soft Top bed Cover, Duraliner,Captains Chairs,Off Road Package, Superchip,3.55 rear,every option you could get except for the towing package.......
