Could someone help me? (Supercrew rotor question)
Im going to do my front brakes on Sunday and was wondering if anyone could give me some helpful hints that they have experienced while doing a brake job on their 02 Screw?
You know the times when you say to yourself "If I only I had known this I would have done it a different way."
I am pretty mechanically inclined but I just want to know if there is anything I need to watch out for or specialized tools I need?
I appreciate it.
Thanks.
I appreciate it.
Thanks.
1st thing you do is compress the caliper BEFORE you take it off trust me this works great and you will get an even compression of the two pistons everytime.
do not let the caliper hang on the brake line
do not touch the surface of the pads with your fingers
clean everything with brakeklean BEFORE you start
put a towel under the fluid reservoir before you compress the calipers as brake fluid will eat through everything
buy specifically made caliper slide grease instead of using high temp bearing grease as it has a higher temp rating
be very very careful when breaking in the new pads
if you need to get the rotors off please post another question as that is another whole ball of wax!!
have fun!!
have fun!!
