Will 2000 F-150 wheels go on a 1983 F-150?
I am the owner of a 1983 Ford F150 and recently I came across a set of 2000 F150 wheels and tires. In my haste to purchase them I did not check to see if the bolt pattern was the same. It is now apparent that the bolt pattern is slightly different. What would be required in order to get these
wheels to fit my 83? If the parts are the same I believe that I would have to change rotors and axles/drums. Is this the case? Are these parts the available? Or is this an impossible modification. If anyone has already done this please let me know what is required to do this.Any information will be greatly appreciated.
Thank you for your time,
F. Salas
F. Salas
