What Size Wheel??
Old 03-14-2004 | 03:33 PM
2003F150Supercr's Avatar
What Size Wheel??
Looking to upgrade my stock wheels and tires on my 2003 4x4 Screw. I have the stock 16" wheels on them now, want 17" wheels and the widest and biggest tire I can get underneath it w/out lifting it.
Should I go with a 17x8 or 17x10 wheel and what size tire can I get to fit without a lift or cutting. I will tighten torsion bar in front to get even with back.
Thanks for any help.
I like the following rims- weld Scorpio V 56 style wheels
http://www.desertrat.com/weld/weld.htm
If you know a place I can get these rims for cheaper, please post also!!
Just need a tough size tire that rides comfortably and is quiet.
Thanks for any help!!
Old 03-14-2004 | 05:25 PM
wandell's Avatar
I would go with a 17x10 and a 33x12.50-17. If you go with a 10 inch wide rim, you will have to crank up the torsion bars and trim a little plastic off the front bumper's lower plastic valance. If you go with a 17x8, you may or may not have to crank and trim.
Old 03-14-2004 | 10:09 PM
Pic of your F150
Wandell-Do you have any pics of your F150 that I can see your wheels and tires..
Old 03-15-2004 | 12:48 AM
Dan21774's Avatar
If you do go with 17x10s I do believe some trimming will be involved.
https://www.f150online.com/galleries....cfm?gnum=3901
Old 03-15-2004 | 01:49 AM
wandell's Avatar
Old 03-15-2004 | 02:19 PM
Wheel Change
Looks like I can get a decent price on 4 Wheels 16x8 now, Now I need to know what tires to put on them??
Any suggestions with the 16x8s now??
Old 03-15-2004 | 09:45 PM
Dan21774's Avatar
I'd probably go with the 285/75/16s.
Old 03-16-2004 | 10:18 PM
GrizfromKY's Avatar
305/70/16s would look good
