BF Goodrich Radial Long Trail T/A tires
Anyone have any experience with BF Goodrich Radial Long Trail T/A tires? Specifically, the LT265/75R16/D size tires?
I was originally planning to put a set of 285/75R16 BF Goodrich All-Terrain T/A KO's on my truck, but I think they will be too much tire for me. You see, I use my truck mostly on-road, with occasional use in snow and on dirt/gravel roads. I am looking for a quiet tire with good rolling resistance and wet/dry pavement traction.
Anyway, I have an F-150 SuperCab 4x4 (no ORP or lift) and want a tire slightly bigger than my stock Goodyear P255/70R16's.
Here are the tire measurements:
BFG Long Trail P265/75R16: 10.9" wide, 31.9" diameter.
BFG All-Terrain P285/75R16: 11.3" wide, 32.9" diameter.
Goodyear Wrangler P255/70R16: 10.0" wide, 30.3" diameter.
As you can see, the Radial Long Trail T/A's are almost as wide as the All-Terrain T/A's. I'll be gaining almost an inch in width over my stock Goodyears with the Long Trails. Also, the Long Trails will give me almost 2-inches more in tire diameter over stock.
The Long Trail T/A's have a less aggressive tread pattern which I like too.
So, unless someone can convince me otherwise, I'll be going with the Long Trail T/A's.
If you own these tires, please let me know how you like them. Thanks!
1998 F-150 SuperCab XLT 4x4 w/ 5.4L, AirAid FIPK, Gibson Swept-Side stainless steel exhaust, SuperChips "SuperChip".
[This message has been edited by bluecrab (edited 02-08-2001).]
bluecrab,
my hat is off to you...too many people wear out expensive at and mt tires on the road, you know what you want...the long trails are a good tire...several friends of mine have these on yukons and tahoes and really like their performance on the road and in snow...the 265 looks good on the 4X4, i was thinking of the 285 also, and changed my mind after much thought...with me, i didn't want to lose the low-end as i do lots of heavy towing...the 265's have worked out really well...good luck, Rich.
-1999 F-150 4X4 XLT SC
-4.6, auto
-3.55LS
-Westin chrome nerf bars
-dual straight pipes
-goodyear mt/r 265/75/16
-hikerdadrich@aol.com
-4.6, auto
-3.55LS
bluecrab. My truck came with long trails from the factory. I've got over 36k on them and they don't show much wear. Traction has been fine in the snow as well. Like you , most of my driving is highway and I've been looking at larger tires without to aggressive a tread.
99 F-150 XL 4x4. Reg Cab Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector. rhino liner and a cool white shifter ball.
bluecrab,
I can’t help you out with that brand but I agree with hikerrich. I just put a set of 265/75/16s on my ’97 4x4 and they look great compared to the 255s, filled up the wheel well nice.
1997 F150 4x4 Lariat, Flareside White/Gold,
Westin Side Bars, Flowmaster 40 w/ dual chrome tips, SuperChip, Michelin LTX A/T 265/75/16
I bought the Longtrail T/A (265/70/17s) to replace my stock Goodyear tires. After only a day, I found that the grip on these tires wasn't much of an improvement. I decided to replace the Longtrails with Bridgestone Dueler ATs and couldn't be happier. They grip better on road while giving you good performance in the dirt and mud. If you never plan to leave the paved road, the Longtrails will probably be fine, but I'd check out the Bridgestones if I were you...I'm really glad that I did. Good luck.
<A HREF="http://www.my-f150.com/swamprat/red14a.JPG" TARGET=_blank> </A> <A HREF="http://www.my-f150.com/swamprat/red1a.JPG" TARGET=_blank> </A> <A HREF="http://www.my-f150.com/swamprat/red16a.JPG" TARGET=_blank> </A>
1998 F-150 XLT 4x4 Off-Road | Red Supercab | Automatic 4.6
3.55 limited slip | 12-disk cd changer | limo tint
Magnum Custom wrap-around grill guard | Offroad lights
Blazer back-up lights | Full-length nerf steps with custom brackets
275/70/17 Bridgestone Dueler ATs
Find out more about my truck here:
<A HREF="http://www.escalix.com/freepage/merlin2/truckpag.htm" TARGET=_blank> </A>
Or email me at melvin02@netzero.net
Bluecrab-
I can't say anything about the BFG Long-Trails, but I can agree with Swamprat when he says that the Dueler A/T's are a great tire. I have them on my truck (265/70/17) and they are really good in the snow, along with the mud and gravel. Very good tractions. I would check into those tires personally. I will be putting a set back on my truck when the time comes, yet agian....
1999 F-150 4x4 Offroad, SuperCab, Prairie Harvest Gold, 5.4L Triton w/ K&N Air Filter, Keyless Entry, Lund Interceptor Bug Guard, Lund Headlight Covers, Lund Screenfront Grill Insert, Vent Visors, Smittybilt Outland Sport Bumper Gaurd w/ Hella 500 & 550 Driving lights, Access Roll-up Cover, Bedliner, Ford Reciever Hitch Cover, Taillight Covers, Bridgestone Dueler AT's
Link to Pictures:
zing.com
Link to Pictures:
zing.com
