Will these rims/tires rub?
Not sure about the 4X4, but there has been problems with 2WD and sizes 285 and larger. You have to adjust the brake line bracket by bending it back and replace the bolt with a round head bolt. Otherwise it will rub and gouge your rims. Tires that size will probably rub on the stabilizer bar and lower control arm. You'll have to do some measuring on your 4WD to see if you'll have similar problems.
