Tire size question...
wandell is correct. I had 305/70 16's with 16X10's and no lift (except for the standard torsion bar crank) I had no issues at all except for the very minor, unnoticable trimming of the front valance. If you are sticking with the stock rims I would go 285/75's because of the narrow width of your wheel. A 305 would be too wide espicially appearance wise in my opinion. I hate too much tire and not enough wheel more than anything.
FMEXPLORER,
Is your truck 2wd or 4wd?
Cause if its 2wd, and no lift, I dont see you fitting 305's under there...no way
4wd then maybe so
The only reason I ask for clarification is because some Dummy at Discount tires tried to tell me I could fit 305 75 16's on my stock 2wd screw.... I just laughed and told him I would stick with the 265 75 16's I asked for to begin with.
4wd then maybe so
dunno if this is the same, but I have an 01 Expy 4x4 and I was able to put 285/75/16 tires on the stock 16x7 wheels without any trimming or problems. Thinking of going to 265/75/16 next though 'cause the low end power and gas mileage suck and I can't afford to re-gear. I do like the look of the bigger tires though.
