ABS Brake problem
ABS Brake problem
ABS Problem on 1994 F150 4x4 with pushbutton control. Rear wheel brakes only. ABS Lite comes on for a second or two after placing ignition Switch to run. Red brake light OK. WHen I get to about 15 MPH, ABS Light comes on steady until ignition is shut off!! Also NO codes when test wire is grounded - not even a blink.
Please comment - help.
THanks
Jim Southard
THanks
Jim Southard
