gearing
Stock gears + giant tires = more strain on your drivetrain, including your transmission. The reason people install different gears when they add giant tires is just to get it back to the original gear ratio. You can also pick gears that can change the original gear ratio with or without giant tires. A common gear change that giant tire guys do is to pick a gear ratio that compensates for the giant tires, makes their truck quicker, and helps climb/tow easier. A common gear ratio for this example would be 4.56.
Taller the tire the taller the gears. I went from stock tires to 35" bfg's and it was big difference in lost power, not to mention the the damage I was causing to the drive train and tranny. However, I knew I was going to go to 4.56 gears so I wasn't to worried when I drove it for the brief period I did.
If you have a 4x4 you will need to change the front gears also...
