Daystar with Welds33's No Cutting or trimming
Daystar with Welds Evos and 33's Nittos. No Cutting or trimming
I just finished it 2004 SCREW with Daystar 2.5, Weld Velocitys 18X8.5 with 6.3" backspacing, Nitto Grapplers 325X60X18 (33's)
Im no expert but I think the back spacing is the key to No Rubbing. That means no cutting or trimming.
https://www.f150online.com/galleries....cfm?gnum=4543
What do you think????
I spent hours on this site trying to figure out what works.....THIS DOES. Not quite a 6" with 35's But came out pretty good I think.
So with more backspacing you can fit a wider tire. I was looking to get a 33x13.5 MT Baja Claw radial and dident know if i could fit it cause of the width. I also want to use and 18" rim, i have a 02 lariat 4x4 and dident know if it would work.
Also are you limited to the wheels you can choose from with the backspacing or can you get any rim with any backspacing??
Back spacing is very important for fit
Call the guys at weld Dist. www.weldracing.com they will make a suggestion let them know what your trying to do...i.e. tires, rims and lift. Even if you dont buy from them they can tell you need for rim and backspacing.
They were a big help.
Hope this helps.
https://www.f150online.com/galleries...y.cfm?gnum=
Hope this helps.
