Power Slot Rotors
quadkeys...I recently upgraded to brembos' cross drilled/slotted rotors with EBC 6000's in the front and Performance plus pads in the back along with stainless steel lines from performance plus brake lines....work well...got the wrong part from performance plus the first time but second time was good to go the EBC's are great...cant beat them...
01 4.6 4:10 gears LS
24" Katana Azzad's/ 305/35 kumho
Flowmaster 40 original SI/DO
pro comp 9000 shocks (fr)
pro comp 3000 shocks (rear)
rancho 5000 steering stablizer shock
Hellwig rear anti-sway bar
Moog heavy duty ball joints (upper and lower)
Front A- arm and front sway bar-
polyurethane energy suspension bushings
BBK 75mm TB
BBK pulley set
K&N Kit GEN II
Power programmer III
HD lower valance
HD speed tubes
Viper remote start 791VX
Stainless steel brake lines
Brembo cross drilled/slotted rotors
EBC 6000 pads
12" Rockford Fosgates HE subs
501s Rockford Fosgate 1500 watt amp
TD oil relocator kit w/ tranny and oil cooler
BBK 75mm TB
BBK pulley set
K&N Kit GEN II
HD lower valance
HD speed tubes
EBC 6000 pads
