Tire Size
Yes you can. You should be fine running 33's or 305's w/ no problems. A 305 is the same as a 33 and a 315 is the same as a 35. Are you running these on stock rims or aftermarket? If you go w/ aftermarket you'll be fine w/ 16X8, if you decide to step it up w/ 16X10's you may have to trim about an inch off your bottom valance on the front bumper. Take a look at Wandell's S-crew, he had to do this w/ his.
