Will 03' stock rims fit on 1999 F-150?
Old 12-07-2004 | 11:36 AM
mg175150's Avatar
Does anybody know if stock auminum rims off an 2003 FX4 will fit on a 1999 F-150 4x4? I believe the bolt pattern is the same but the stud diameter is bigger on the 2003.
Old 12-07-2004 | 02:31 PM
way fast witey's Avatar
the 9.75 rearend has 14mm studs and the 8.8 has 12mm.i'd say they'll still fit if you have 12mm.i've got expedition rims on mine and they must be for 12mm cause they're alot tighter than my old rims(which were the exact same 17's)but they fit.
Old 12-07-2004 | 06:11 PM
whiskey08's Avatar
I swapped rims from 03 fx4 to a 98 4x4 so Im guessing they should work on a 99 4x4
