Newbie Needs Tires
Old 12-13-2004 | 10:40 AM
Jeeperforlife's Avatar
Question Newbie Needs Tires
I just recently purchased a '99 F-150 4wd RegCab Shortbed and i was just curious about how big a tire i can run with no lift. I plan on buying a set of 16x8 wheels with the tires (most likely MT CL II) Can i run 285/75-16's? I know this has probly been covered in the forum, but i couldnt find it exactly, and i want to be sure. BTW, dont be mad because of the name, i love my jeeps but i was born a ford guy. Thanks
Old 12-13-2004 | 04:00 PM
japickar's Avatar
You can run 285 with no problems. In fact, you can run them on your factory rims without any problems (that's what I'm doing). If you're going with 16x8's, I would also look at the 305/70/16. It's the same height as the 285 just an inch wider (285 is 11.5 inches wide, 305 is 12.5 inches wide). It's just up to you.
Old 12-13-2004 | 04:46 PM
wandell's Avatar
I'd suggest going with a 305/70-16 (33x12.50) on a 16x10 inch wheel. This combo will fit by cranking up the torsion bars and/or trimming a little plastic off the front bumper's lower valance. Here's some pics of my truck at stock height with 16x10 Eagle 058's and 285/75-16 (33x11.50) BFG AT KO's.
Old 12-15-2004 | 08:09 PM
thanks for the help guys. Ill hafta think about it...ill post some pics when i git er lookin like i want.
