ABS sensor vs ABS module
What is the difference between the two?
Can I assume the module collects the data from all the sensors and relays that back to the computer?
Got a 2002 F150 SuperCrew where the ABS light came on and they(the Ford dealership I took it too) said it was a bad ABS module. My computer was communicating to everything else except that ABS module.
Thanks.
Thanks.
Originally posted by UndauntedGSX
The ABS module is a little computer hidden behind the dash. The ABS sensor could be a wheel speed sensor (if you have 4-wheel ABS) or the speed sensor tapped into the top of the rear differential (for those with rear ABS).
His 02 has 3 wheel speed sensors, 2 fronts and 1 rear mounted in the axle.
