33-12.5-17 v 285
Old 01-25-2005 | 01:06 AM
Auburnoffroad's Avatar
33-12.5-17 v 285
I have a 2001 f150 with the off road package and 265-70-17 stock tires. I want to upgrade to either a 285-70-17 or a 33-12.5-17. I was wondering what the difference is between them and if I went with the 33's would I have to trim and would they stick outside the fender. Thanks for any help.
Old 01-25-2005 | 09:00 AM
wandell's Avatar
The 285/70-17's work out to be approximately a 33x11.50-17. Both tires are the same height, the 33x12.50's are just an inch wider. Whether or not they stick out depends on what rim you use. Mount them on a 17x10 inch wheel and they will be about even with the edge of the fender flare. Go with a narrower wheel and they will be completely inside the fenderwells.
Old 01-25-2005 | 03:16 PM
I'm going to keep the stock wheels so I assume those are 17 by 10? Which would keep it still under the flare.
Old 01-25-2005 | 04:46 PM
bonefish's Avatar
No. Stock is 17" x 7.5". If you are going to keep the stock wheel then I would suggest the 285's.
Old 01-25-2005 | 05:32 PM
wandell's Avatar
Right, the OEM wheels are 17x7.5.
Old 01-27-2005 | 12:40 PM
MyFordTruck98's Avatar
I've had the 285's on my truck for years, granted they are on 16" wheels, but they really fill out the fender wells well. Oh, and WAR EAGLE!
Old 02-03-2005 | 09:24 AM
tlapan93's Avatar
On my 98 I did the torsion bar lift approx 1" and put 305 70 16 on my stock rims. I had no rubbing problems, just poor gas mileage.
