How to tell when RTS's are worn out?
Old 02-12-2005 | 05:35 PM
white elephant's Avatar
Question How to tell when RTS's are worn out?
So many people dog the stock RTS's on the 97-03 body style 4x4 ORP's but I have 70K on the originals w/ more to go. The traction in snow isn't what it was, but it still isn't bad.
Unlike most tires the 265/70/17 RTS's have triangular ***** molded onto ~ a 3/16" shoulder. Although it sounds like a simple question, how do I tell when they are worn out? Are they shot when the triangular part is worn to the shoulder or when the tire is worn down and the shoulder only has ~1/8" or so left? As it is I have ~1/16" of triangle on top of the shoulder. If I measure from the top of the triangle to the lowest part of the tire, I still have ~1/4".
Old 02-15-2005 | 01:32 PM
62 views and no one knows!
Old 02-15-2005 | 02:21 PM
bonefish's Avatar
When you have worn down to the tread bar, then its time to replace them.
Old 02-15-2005 | 05:00 PM
Is the tread bar what I'm refering to as the "sholder" that the triangular ***** protrude from?
Thanks!
Old 02-15-2005 | 05:18 PM
wandell's Avatar
They are the little bars between the tread of the tire. They are usually near the center of the tread.
Old 02-15-2005 | 06:20 PM
Johngs's Avatar
Also, they usualy go from side to side.
