What will fit
35's are too wide for stock rims. About the biggest you want on the stock rims is a 265 (32") or 285 (33")
jquinn:
you can fit 285's on there without any modifications, maybe some trimming of the valence or a few turns on the torsion bars if anything
305's will probably cause some rubbing (you can crank the torsion bars some and/or trim the valence)
315's would require a lift along with cranking the torsion bars or trimming the valence (or both).
jquinn:
