What are my rims?
What are my rims?
Hello All,
Cant seemto find this information anywhere. I have a 2001 5.4 f150 with ORP. I have the 17x7.5 factory saw blade rims. I am hunting for new rims. What is the configuration of these rims?? I know they are 5 lug (obviously). What are the other specs?? Bolt pattern?? Backspacing??? Load range??
I want to replace it with something that is similar, maybe 15x8 or 16x8, but I do not want to have them stick out pass my fenders...i really like the M/T Classic Locks!
Thanks for your help!
Rich
Rich
The backspacing will depend on the width of the wheel. Most mass produced aftermarket wheels (4x4) will have a neutral back spacing, ie. hub face in the center of the wheel barrel (4 1/4 backspacing on an 8 in wide wheel) pushes wheel out of fender well. Most stock wheels and large diameter wheels have a positive backspacing, ie. face of wheel out on the outer lip of barrel (5 3/8 backspacing on a 7 1/2 inch wheel, wider on large diameter) Tucks wheel into fender well
The stock backspacing on all the 16x7 and 17x7.5 inch wheels is 4 1/2 inches. Most of the 16 and 17 inch aftermarket wheels for the 97-03 F-150's have 4 1/2 or 4 5/8 inches of backspacing. I have 16x10 inch wheels on my Screw with 4 1/2 inches of backspacing and the edge of the wheel and tire is just about dead even with the edge of the fender flares. You won't have a problem with the wheels "sticking out" if you go with an 8 to 10 inch wide wheel.
