Hubs overheating
Hubs overheating
Allright yet another problem because I dont read anything. The front hubs are overheating and smoking after a short drive. One of the dust covers actually blew off because of the heat. What do yall think could be the problem. I put a whole lot of grease in them and Im pretty sure they are not overtightened.
Any help is greatly appreciated.
I used wheel bearing grease. I put a whole lot in the hub and when I put in the inside bearing i filled the area between the bearing and inner seal with grease completely. I thought it was a good idea. And I dont think I overtightened them cause yesturday I backed the nut off and it wasn't real tight.
I don't think you can over grease the bearings. With new pads and rotors they will run hot until they bed in. The dust cap is hard to put on because the grease seals the air in the cap causing pressure when installing. On my 82 bronco, when i put my caps on i put a pin hole in the cap and then put a dab of sealer on it after it was installed. I was repacking the bearings every couple of weeks due to driving in creeks and mud
Take them off again and remove all the grease between the front and rear bearings in the center of the hub. The extra heat is probably coming from all that grease just rolling around in the center of the hub and the spindle.
Mitch
