Alignment Problem
Alignment Problem
Question for everyone. I installed my Autospring 2 1/2" spacer Fri night without too much trouble, and had 17x8 MB Motoring Blitz wheels with 315/70-17 BFG AT Tires put on yesterday. I have been to 2 differnent tire shops and both said that the rims have no lip to get the alignment racks on. Looking at the rims and tires it seem that they are right, the rims have no lip, and the BFG AT tires overlap the edge of the rim, leaving nothing to mount the aligment racks.
I know Porkchop has the same rims with Nittos, so I was wondering if anyone had any suggestions.
Unfortunately, when I had the new rims and tires mounted, I had the old tires taken off the stock rims and disposed of as the had over 60k on them, so right now I have no other choice but to have the alignment done with the new rims and tires.
Dave
Dave
A good alignment shop will have adapters that go on the outside of the wheel between the wheel and tire. If your alignment shop doesn't have these simple standard items....maybe you should re-think where you are getting your alignments done.
Is it a digital alignment machine? The newer machines are accurate to .005 degrees. The resolution on the machine will show .01 degrees of adjustment. If the technician knows what they are doing and wants to they can get it perfect.
5,000 alignments plus under my belt...thank you
