Strange Rear Brake Squeak
I've searched the forums for "brake squeak" and "brake squeal" but didn't see anything addressing when the rear brake squeaks. I suppose a disc brake works the same way whether on the front or back of the truck, anyway, here goes...
I've got a 2003 F150 XLT FX4. It's got 4 wheel disc brakes. Only 17,000 miles on it.
About a second, maybe a second-and-a-half after I apply the brakes there is a short squeak--lasts about a second (or less)--which I believe is coming from the right rear brake. This doesn't happen every time I apply the brakes, I'd say about 50% of the time. It's become quite annoying.
I looked at the rotors and except for some slight pinhole sized pits here and there they look fine. There is a lot of pad life left.
Although it's under warranty, I'd rather not bring it to the dealer and be without the use of my truck for half a day. Anybody else have this problem? Anybody know of a fix?
brake squeal
I`ve got a 2004 F150 4x4 I`ve had the same problem (you can read it a few post down) I took it in to the dealer they checked it couldn`t find any problems, but they did sand the pads it didnot help I plan to take it back as soon as posible try to make them replace the pads on the driver rear side.
