Tire pressure
Thats very high.
I have 265/75R16 BFGs and I only run about 40 PSI all around. Slightly lower in the back, about 35-38 PSI.
If you haul alot of stuff with your truck, then you will want to jack up the PSI, but otherwise thats way too high for an empty truck and the tires will wear improperly.
I have 285/70/17 BFG A/T. I run 45 PSI in all 4 tires normally. If I am towing a trailer with heavy tongue weight, I go up to 60 PSI in the rear tires. The tires wear well with the 45 PSI.
DO NOT pay any attention to FORD's tire pressure recommendations if you are running any tires other than those that came on your truck. The truck's placard information is relevant only to original equipment.
If any components are changed from original, the new component's specs should be referenced and heeded for safe, efficient operation.
When you change the tires to a type other than factory type, you should heed the recommendations listed on the tire's sidewall. If memory serves, the sidewall of my BFGs indicates a maximum of 65 PSI. The tires are not designed to operate at the lower pressures shown on the trucks placard.
If you run "LT" rated tires (BFG A/T's are "LT" rated) at the pressures indicated on the truck's placard (my truck's placard says somewhere around 35 PSI for the factory "P" rated tire) the "LT" rated BFGs will wear prematurely at the shoulders of the tire.
The max psi listed on the tires sidewall is for towing/hauling heavy loads, not for daily driving. While the tires will be ok at max psi, they will ride very rough. If you have any doubts, by all means contact the tire manufacturer and see what they recommend. I bet it will be a lot closer to Ford's recommendation than the max psi listed on the sidewall of their tire.
on our f250 light duty we run the tires at 50psi- they are either c or d range- dont recall at the moment- and on my f150 i run them at 35 psi as it says in the fuel door. both trucks have goodyear rt/s tires and are wearing perfectly with no rotating so far on mine at 9000 miles and have only been rotated once on the 250 at 30000miles- has 45000 on it now.\
Dan.
Dan.
It's a truck, not a Lincoln Town Car. It's supposed to ride like a truck! If you don't want to feel the piece of gravel on the road that you just ran over, don't buy a TRUCK....buy a CAR!
EXAMPLE........ Ford also recommends 87 octane for the F-150. If you use aftermarket (read other than stock) tuning, ie:SuperChips module or 1715 MAX MicroTuner, that recommends 91 or higher octane fuel, would you still heed Ford's advice and use 87 octane fuel? I certainly hope not. Of course, a sane person would heed the aftermarket vendor's advice and use the appropriate 91 or higher octane fuel to accomodate the deviation from stock.
Installing "LT" rated BFG/AT's is also a deviation from stock and the manufacturers recommendations should be heeded to avoid premature wear and poor performance of the aftermarket part(s).
Here is the key...If the door placard recommends 35 psi, it will also state that the tires on the truck are P265/70/17. Are your BFG All Terrain Ko's P265/70/17? If they are not P265/70/17, then the inflation rates on the placard cannot possibly be applicable to your tires, as they are not the same spec.
Bottom Line.....The door placard is only applicable for FACTORY INSTALLED COMPONENTS.
Sheesh!
