Help. Is there any type of "wider front fenders" on the market for a 2005 f-150 ?
My truck will be lowered 6" on front and 9" on rear, i got 24" wheels and 305/35 tires. On both front and rear, the tires will have to go to the inside of the fenders. I know i will be ok on the rear because the fenders are a lot more wider than the ones from the front . My big concern is the front fenders, they are not wide enough to fit the tires inside it. I would like to keep the 305/35 tires so i am looking for wider front fenders. If i don't find the wider fenders on the market i will have to go with thinner tires like 275/35 or even less and that is what i am trying to avoid. I gonna appreciate if someone can help me with that. Thanks a lot guys.
Too many posts.
webmaster
Administrator Join Date: Nov 1996
Vehicle: 1997 Ford F150
rafa26,
I have removed several of your posts. Please refrain from "cross-posting" your message to several forums. It is very poor forum etiquette. Thank you.
Sorry, i am new to the forum and i don't know the rules, i am just in a hurry with my issue. Thanks.
rafa26,
This link might help.
http://en.wikipedia.org/wiki/Crossposting
The rule does not just apply here, but to message boards in general.
As you found out, posting the same message several times will not result in getting a question answered any faster, as it is our policy to remove cross-posted messages.
Try Jd Fabrication
Jd fabrication has some fiberglass front fenders. check out there web site.
http://www.jdfabrication.com/kits/2004_f150.asp
check the bottom of the page under the extras section.
i hope this helps.
i hope this helps.
It appears they have rear fiberglass too according to these pics.
http://www.jdfabrication.com/photos/...x4/f1504x4.asp
