I just got my 04 f150 and the tires that came on it are almost bald. What would be the largest tire size i could put on it without adding a lift or aftermarket rims. Thanks for your help.
without a leveling kit the biggest you should go is 33's but if you get a leveling kit you can run 35's with a little rub. I run 305/70 with a 2.5 leveling kit and it fits fine.
