BF Goodrich 285 65r 18
Originally Posted by Rochester
SAJEFFC,
Those tires look sweet. What tires did you have previously that gave you a bumpy ride? Did you have any decrease in gas mileage with the new tires?
Okay actual measurements of the 285/65-18 BFG A/T KO's. Height exactly 32 inches from the ground to the top. Width **** to **** 9 inches. Width from the widest points (the bulge) is 11.5 inches. These measurements are with 8 inch wheel. They look a lot larger than the 275/65-18 Rugged Trail T/A's. I am still trying to figure out how to insert a picture on the message board. If nothing else I will update my gallery with an album next week.
the reason you are getting a smaller measurment is the weight on the ground squashes the tire on the bottom. to get a accurate measurment you need to measure the tire befor you pyt it on the pickup or measure horizontaly front to back. you will get a mor acurate measurment that way and I am betting it will be alot closer to the correct measurment for that tire.
