need tires!
Hey Raptorracer,
Check these wheels out...
Personally I like the ones with the Trail-Ready Rim Lock look. That's just an add-on piece you can get. I also think 17's or 18's look good on 4 X 4's. A little more $$$ though. I like the Mickey Thompson Beadlock simulators too. Bead Lock's give an aggressive Off-road look.
FYI 5 on 5-1/2, 6 on 5-1/2 etc. is the Bolt pattern in the description as dodge_slayer said.
If you will call 4wheelparts they can tell you everything you need to know as far as how much backspacing to get, what bolt pattern to fit your truck, and what size tire to get so you don't rub....Don't get to much offset or to much tire or you will rub evertime you make a tight turn
That's my 2 pennies
That's my 2 pennies
Most people will tell you that most of the people at 4Wheel Parts have limited knowledge. Most are just reading info off their computer provided by manufacturers as far as tire fitment. For instance, a recent tire fitment charts in one of the 4x4 magazines listed a 31x10.50 as the largest tire that would fit on our trucks. Most of our trucks came with 32x10.50's (265/70-17) from the factory! Several members here have fit 35x12.50's on stock 4x4's. I've found that the people who actually own and live with a vehicle are a better source of information. Thank God for sites like this!
