Clearance for new Tires
Old 10-06-2005, 01:05 PM
jdgore2's Avatar
I have a 2004 FX4 with 17" rims. I currently run 255 that came stock. I wanna upgrade to 305's. I don't have the leveling kit on the front of the truck, so does anyone know if I will have enough clearance running 305's without having to purchase the leveling kit. And what can I do about the speedometer after I get new tires?
Old 10-06-2005, 01:31 PM
jdgore2's Avatar
And just wondering if instead of 305's, should I go with 285's. And besides BFG KO's, what other tire is out there. I havent been able to find any Dueler AT's at that size, althought they have them in 305's.
Old 10-06-2005, 01:53 PM
KickinBlue4x4's Avatar
Nitto terra grapplers, Goodyear wranglers, Pro-comp A/T, the list goes on. I really like my pro-comps. I would go with 285's personally, but it depends on the tire/wheel combo. How much offset and what size tire you have is what makes all of the difference, along with how wide the tire is.
Old 10-06-2005, 03:56 PM
wandell's Avatar
I would go with 33's whether you decide on a 285/70-17 (33x11.50) or a 33x12.50-17. You can get your dealer to recalibrate your computer for the largest OEM size available (275/65-18) which is almost 33 inches tall. Or you can just buy an aftermarket computer tuner (Hypertech, Superchips, etc) and do it yourself.
Old 10-18-2005, 10:49 PM
Not again?!'s Avatar
Hello,
I'd like to know for certain if 285/70/17's(ie. BFG AT KO's) would fit on an '04 screw 4x4 standard rim without any suspension modifications? I have solicited several opinions from some "knowlegable" rubber shops and the dealer. No answer is the same. Some yes, some no and a few shoulder shrugs. This post is the closest I have found (thanks in advance). The tire shops are hedging their answers it seems because this size exceeds 3% of the OEM size of 255/70/17. If I buy the tires from some place like tirerack.com, they will not mount/balance them. I am certain this is their way of protecting their pricing schemes.
Again, thanks in advance.
Old 10-19-2005, 07:57 AM
wandell's Avatar
Yes, they will fit easily.
Old 10-21-2005, 02:47 AM
6T6CPE's Avatar
I have 16" rims. I had 285 Dueler MT's (yuck) and they did not rub. I put the exact same size Dueler Revos on and they rub the factory mud flaps when you cut the wheel all the way from side to side.
Old 10-21-2005, 06:53 PM
rustyst's Avatar
I just put a set of BF Goodrich A/T's on that were 315/70/17 on stock rims, fit great and look awesone. The guys in the shop told me to put 9 inch rims on or it wouldn't ride right, but I think it rides fine, better than before with the General tires. I will certainly have to have the speedo recalibrated, its definately off.
Old 10-21-2005, 07:29 PM
slowrancher's Avatar
I'd like to see some pics of those 315's.Ive thought about taht myself
Old 10-23-2005, 08:05 PM
ohkyguy's Avatar
tire question
I am sorry to ask this. I am sure this has probally been discussed before. I have a 2004 f-150 SC 4x4 and I want to put 33 12.50 17's on my stock truck with stock wheels and no lift or leveling kit. Will this work without rubbing??
Old 10-23-2005, 08:11 PM
wandell's Avatar
Yes.
Quick Reply: Clearance for new Tires
