Need opinions
Originally Posted by wandell
Those are basically a 33x12.50-22 tire. Since you have an FX-4, the wheelwell gap will be about the same as it is now. I'd suggest removing the 2 inch lift block from the rear.
so if i have this removed the truck should level out right? i put the rims and i'm happy with the gap in the front but the rear is a bit much. would i need to do any modifications if i remove this block? thanks for your help
