bigest tire for 4x2
Originally Posted by firefighter5318
hello,
i was wanting to know what is the biggest tire that i can put on my stock rims.i have a 2002 ford f150 xlt 4x2. i have 245x70x16. i was wanting to know if i could put like 275s or 285 or maybe 265
hello,
Originally Posted by Zaairman
The biggest you can fit without rubbing or any trimming is a 265/75/16 with your stock 16 inch rim. They are all giving you different sizes because they all have different rim sizes....
2wd F-150's came with three different size tires (excluding Lightning).
235/70R16, 255/70R16, and 275/60R17. If your truck does indeed have the 245/70R16, then I am guessing it was replaced at one time with the wrong size. With a stock rim, you could try the 255/70R16 or if you are upgrading go with the 275/60R17. They are actually both the identical height and it won't be necessary to reprogram the PCM should you go with the larger wheel. Of course, it all depends on what kind of look you want too. If you want the look of a 4wd then possible a 265/70R17. This is considerably taller than the others. Hope this helps you out. To determine what size your truck came with from the factory look at the sticker inside the drivers door jam.
just double checked and ya they are 16. tire has written on it" 265/75/r16. ive never replaced the rims on it and i bought new. as for the look, i want i guess the best of both worlds. something with some bling, but will look like there ready for mud at any time. i know i might be wishing but....
