rear brake caliper stuck
Old 02-27-2006 | 02:58 PM
Jimmy in Austin's Avatar
Ok, I got past the rusted on rotors by using the method desribed here:
Y2K 7700 4x4
09-09-2000, 03:36 PM
Tip from an old brakeman:
Apply penetrating oil to the studs and hub-pilot (not wetting the rotor faces). Put tire/wheel back on, but finger-tighten the wheel nuts. Drive truck forward/backward sharply stabbing the brakes to loosten the grip of the discs from the hub. Remove tire/wheel and resume removal as per suggestions above.
https://www.f150online.com/forums/ar...p/t-10109.html
But since I put my old pads back on and did that stop & go method, my caliper on the left side has become stuck in the outward position. My C-clamp is getting me nowhere. I even tried attaching a wrench to the end to give me move leverage. All that did was start to bend the handle on the C-clamp. I've sprayed it pretty liberally with some penetrating oil...
Any suggestions?
Old 02-28-2006 | 10:45 AM
19 views & nobody has a clue....
Come on, where's the help at around here? Somebody has to have the answer to this...
Old 02-28-2006 | 02:36 PM
Kool Aid's Avatar
Are you talking about the piston?
Or the caliper itself on the slides?
Old 02-28-2006 | 09:43 PM
Oops. The piston. It is what is stuck.
Old 02-28-2006 | 11:13 PM
Yankee7985's Avatar
Replace the rear calipers.
Old 03-01-2006 | 05:13 AM
Kool Aid's Avatar
It's possible the piston came out too far, and it's crooked in there, and hung up.
If so, it's also probably no good at this point.
Your going to have to pull the rubber seal, and check to see if it's got the piston messed up, before you go any further.
I would use several clamps spaced around the piston to see if it will go back in, after checking it for damage.
Good luck.
Old 03-01-2006 | 04:04 PM
GIJoeCam's Avatar
I would mirror what he said, but would also add a "Why Bother?" at the end.
Personally, I'd just replace the caliper. They're relatively inexpensive, readily available, and most of them come with a warranty. .
-Joe
Old 03-02-2006 | 08:19 AM
bumpnzx3's Avatar
just a sug.- i may be wrong since i am not familiar with the workings of the f150 brakes. but- i had much this same problem on a car that i did a brake job on once. i too tore up a c-clamp trying to push the piston back in. depending on how the emergency/parking brakes work on these trucks- you may have to turn the piston back in. there is a special tool to do this- but i always use a screw driver. look at the face of the piston- does it have an "X" or a couple small holes cast in it? if so- the piston needs to be turned back in- almost like it has really large threads.
like i said- i am not familiar with the f150 brakes yet- but it's just something you might check. i know i felt like a complete tard after a friend clued me in on what i was doing wrong.
Old 03-02-2006 | 09:48 AM
GIJoeCam's Avatar
Not on the F-150s and Expeditions. They use a completely independent set of parking brake shoes that ride inside a small drum in the center of the rotor.
Good to keep in mind when working on GM products though...
-Joe
Quick Reply: rear brake caliper stuck
