Will they fit?
Will they fit?
First post and obviously its because I need some advice. I have an '05 Supercrew 4x4. I'm looking at 20x10 wheels with 4 1/2" backspacing and want to put on 305/50/R20 tires and I need to know whether they will fit or not at stock height? I know the 285's will fit, but I want the width of the 305. Any advice would be greatly appreciated.
Chad
Chad
The tires will easilly fit, with the right wheel. However, I don't think that wheel will work too well. It's gonna stick out 3 1/2 inches farther than the OEM wheel. If you can find an 9 to 10 inch wide wheel with around 5 1/2 inches of backspacing, the tires will fit and look much better.
That sounds more like it. I'm not sure how much the new Expy's have in common with the new F-150's, but the OEM wheels are the same specs. I am running 305/45-22's on a 22x9.5 inch wheel with 6.7 inches of backspacing. My tires are basically a 33x12.50 while the size you are looking at are a 32x12.50. One of my tires does touch my antisway bar at full steering lock. I never noticed it while driving, but while doing an oil change I saw where it had rubbed the paint off the antisway bar.
