Help !!
Help !!
Hey guys, Im buying some procomp mud terrains (35x12.50R17) and I was going to keep on my stock wheels but I at least need a 8.5" wheel. I dont want to do to much trimming of valences, torsion bar raising, etc. Is there a way I could go with a bigger wheel and have it be offset a couple inches to make up the difference. If you could let me know what wheel sizes you have on your trucks?
Any suggestions will help.Thanks
285/75r16
I put Cooper S/T 285/75R16 on my 2001 screw I had to adjust the torsion bars and trim about 2inches of the lower valance but the wheels are 16x10 with 4 inch back spacing not 4.5 like the factory which will make a the tire move forward and back farther than the stock wheel not to mention the extra width of the wheel. I would bite the bullet and get a 18mm socket, sawzall and a 15pack of Molson Canadian and make them fit
Coopers web site says that the S/T 285/75R16 is 32.8 in tall the tread is 9.2" wide. This is from www.coopertires.com If you want you can check out the pics of mine https://www.f150online.com/galleries....cfm?gnum=7341 or click on the camera at the top right of this message
P.S.It is good to hear from somone close to home I am about 10 miles from the Oilmont Exit on I 15
Siefs
That is a nice looking truck. Thats funny your last name is Seifert, my best friends last name is Seifert and his whole family is from South Dakota. I might just go with BFG Muds and use my stock wheel for now with a 3" body lift. I cant afford wheels and tires right now cause I am buying a house.
