Wheel Spacers
Wheel Spacers
Ok I have a slight problem with my truck when I make a sharp turn the front wheels rub the frame a little (so i avoid it and dont make sharp turns!) So what I want to know is how hard is it to put wheel spacers on? What ones are the best? Do I have to replace the studs and all bc I thought I seen one where you didnt need to but i could be mistaken? I would like to go with a thick set so my tires are pushed out and look more aggressive anyway so this way I kill 2 bird with one stone. (Post links if possible) Thank you all in advance for your help!!!
ruba dub dub
you didn't say how big your tires were or what the offset and width of your wheels are but if you use wheel spacers you may go from your tires rubbing at full turn to rubbing at half turn on they fenders or bumper. The more you move them out the farther the arc that they swing when you turn
