Helo Maxx 6 help
Helo Maxx 6 help
Hello All,
I'm planning on picking up a set of Helo Maxx 6's for my '01 F150 4x4 (ORP).
They have two available in 17x9 (5-135) at tiresdelivered.com. The only difference is the offset, one is 10 and the other is -12. Can someone tell me which will work best for my truck?
Also, I'm looking for suggestions for tires. I currently have 265/70/17's. I'd like something that will fill up the wheel wells without rubbing. The height is stock except for cranked torsion bars.
TIA,
Jerry
TIA,
Jerry
Originally Posted by JerryM
Thanks for the info Wandell!
The local wheel and tire shop seems to think I can fit BFG 315/70/17's without a lift. Can anyone confirm this? Will 315's be too much for the 4.6 with 3.55 gears?
I am going to put a body lift on my truck and get new tires and rims. I am going to get 16x10 rims and 35x12.5 tires. Will I need to regear bad? I dont have the towing package but I do have the 5.4, exhaust and soon to have a programmer and an intake soon. I dont know what gears I have. Is their anything else I should know when doing all of this? I am not installing the lift myself. I am only going with 16" rims because tires are cheaper and one of my rims is bent so I already need to buy some.
if you slide under the truck and look at the rear diff there is a tag on the diff cover bolt it will tell you the gears inside 355, 373. I will tell ou this I have 315 on my truck now and they are killing my gas and power it is a slug. I just bought helo maxx 6 with 33x12.5 16 no more 17 for me to small of a selection in tires+there cheaper. If you do gears at least 4.10
