what will fit
Old 04-05-2006 | 11:57 AM
Garster's Avatar
Originally Posted by wandell
RIght. You can fit 315/70-17's (35x12.50) on a stock 4x4, but it is a tight fit. THe secret is to use the OEM 17x7.5 inch wheels. You will have some minor rubbing on the frame at full steering lock. Personally, I wouldn't go with them unless you plan on a lift in the near future.
Yes, 315's are a very tight fit without a lift. I'm running a set on a 99 F250LD (7700) and besides the clearance issues you will lose a good bit of engine performance. I have 3.73 gears and noticed it immediately, i had 305/70/16 on before and should have stayed with that size. The 305's with the right wheel fit very nice
