CrossDrilled? Slotted? Both? Dimple?
I have been searching around, but have been unable to get a solid answer for my question. I am going to buy some new rotors. I was wondering who has had the best luck and with which? I want something that will last the longest and I will be able to turn if needed. Can you turn slotted? I know they say you cannot turn cross drilled. I was thinking of just slotted?
What are your opinions?
Thanks.
Thanks.
hah! good luck on getting a 'solid' answer. Take a search through this forum, there are numerous long long long posts on the subject, and no 'solid' answers.
Myself? Unless I was looking at heavy towing or hauling, f I were going to upgrade any part of my braking system it'd be the tires. That's 'where the rubber meets the road' so to speak.
Originally Posted by b_j__h
I have always wanted the cross drilled and slotted rotors, myself. I would have to think that they would help your stopping ability due to the reduced heat and gases.
--Joe
Hey guys thanks for the opinions. My blanks are warped and also not turnable, they have some nice grooves in them, so it is time to switch them out, this is the ONLY reason I am changing them. I keep my Expedition pretty much stock. I have read over and over and heard how the Expedition brakes are pretty weak and warp easily. I do tow up to 4,000-5,000lbs. This is where the brakes get used the most, when I am not towing the car is used by my wife, to take my son back and forth to school and she does not drive it hard. I do notice when I am towing my boat and have a car full of people, it does not want to stop and heats up fast, especially going down big hills. I am going to give the slotted only a try. I just want the brakes to cool down a little faster in between brake bursts going down hills with the family and boat.
BTW: I am getting my rotors through www.rotorpros.com good place.
Thanks.
Thanks.
https://www.f150online.com/forums/sh...d.php?t=224360
montzsta,
above ia a string that has TONS of both very technical and simply put info in it. Kinda long but I think it will help you make your decision.
If you don't have the time than the basic synopsis is get good pads (EBCs are good) and good flat rotors and the important part is flush and replace all your old brake fluid.
don't waste your money unless your looking for the drilled or slotted look.
Cheers!
montzsta,
Cheers!
