one last thought....
im about to buy my super swamper trxus all terrains today or tommorrow. they are sized 38X15.5 R18. This will be going on Mazzi Hulks on a fabtech 6 inch lift with 3 inch PA body lift. I just want everyones last opinion on the tires and whether i should go with a less wide tire or not, and what tire if so. How much rubbing will occur?
your width is probably the lesser of the two evils of the tire--the 38" height may produce a bit of rubbing- you may want to search down in the 04-06 forum for Josiah and his 6" fabtech and his consideration of putting a 3" body lift on with his 37 nitto mud grapplers & mazzi hulks also- bigyellowtruck just put a 6" and a 3" on with his 38's and has a bit of rubbing i believe
