Need confrimation
Need confrimation
I've been researching putting 20" Moto 951's on 33's on my 04 Screw w/ a 2" autospring leveling kit. Everywhere I look, I get different answers. I hear they will be fine w/no rubbing. I hear they will only rub when you go backwards. And I've heard they rub realllll badly.
Does anyone here know for sure what will happen?
Also, if they do rub, what do you recommend doing; smaller wheel size , smaller tires, or both?
I have Moto 951's with 305/55R20 Toyo open countrys and yes they will rub because of the 4.5 backspacing only when you turn real sharp you can actully trime out the plastic if you wanted to to reduce it but if you do any hardcore off roading take it easy on the turns OHH and I have the 2.5 daystar lvling kit. I also have the Superspring helpers on the back. Alot of people say you dont get any lift from helper springs but with the suppersprings you get about an inch useing the optional lift holes. And there easy to install and serve two perposes.
geez, that worries me bc I tow a 12ft trailer around and gotta take sharp turns sometimes. Maybe this is a bad idea?
Ok I need to start a photo album any ways. Ran outside took some pics of my dirty truck. Picture of the triming I did. I do alot of towing also and before I trimed it was driving me crasy.
