285/70r17
285/70r17
Hey, I am doing a 6" fabtech lift to my 2004 F-150 2wd, if I go with 285/70R17 BFGoodrich AT KOs and 17x9 wheels - Do you guys thinks these tires will look way to small for this setup? Not going to 35s because I dont want to have to regear. I have the small 4.6L V8.
Thanks in advance
Paul
Thanks in advance
Paul
Thanks in advance
Paul
Thanks in advance
Paul
I think the 285s will look too small for the 6 inch lift....if you gonna go with the 285 tires when just do what the other fella said go with a spacer and lift blocks or whatever you want....but I say keep your money if you gonna get the 285s dont get the 6 inch lift save that money and get some nicer wheels on the 285's and do other mods also...ull be happier that way if all you want is the 285's...
jus my 2 cents
jus my 2 cents
What if I went with a 315/70/17 - Is that considered a 35" tire?(dont want to have to regear) Would that tire work with my 17x9 wheel? Would it fit well? Any suggestions at all would be great, I already have my 6" lift in, so I'm not going to send it back.
Paul
Paul
35's and gears would be the way to go. You have the 8.8" rear end with the 4.6, so aftermarket gears are readily available and cheaper than the 9.75" rear!
