06 fx4 18x10 wheels fit???
I think with that wide of a rim you will probably be limited to a 33" or shorter tire with only a 2.5" lift. I'm still searching too, I have a similiar setup with the AS 2.5" lift. The rims I have an eye on are 8.5 wide with a 5" backspace and will probably run the new BFG KO in a 305/65/18 when they become available.
That wheel only has 4.5 inches of backspacing, which I don't think is enough. To give you an idea, your OEM wheels are 7.5 inches wide with 5.5 inches of backspacing. Those Eagle model 064 wheels will stick out 3.5 inches farther than your OEM wheels. Eagle's 18x9 inch ( with 5 inches of backspacing) model 178 would be a better choice. It would stick out about 2 inches farther than your OEM wheels.
